Extension File Format
Extensions are composed of at least three files, extension.json, readme.md, and one or more python files. The Logic 2 software uses Python version 3.8.
extension.json File Layout
A single extension can contain multiple high level analyzers, measurements, or both.
This example is a for a single extension that contains one high level analyzer and one digital measurement.
"version": "0.0.1",
"apiVersion": "1.0.0",
"author": "Mark Garrison",
"description": "Utilities to measure I2C speed and utilization",
"name": "I2C Utilities",
"extensions": {
"I2C EEPROM Reader": {
"type": "HighLevelAnalyzer",
"entryPoint": "I2cUtilities.Eeprom"
"I2C clock speed measurement": {
"type": "DigitalMeasurement",
"entryPoint": "I2cUtilities.I2cClock",
"metrics": {
"i2cClockSpeed": {
"name": "I2C Clock Speed",
"notation": "N MHz"
"i2cBusUtilization": {
"name": "I2C Bus Utilization",
"notation": "N %"
The author, description, and name properties manage what appears in the Extensions panel where the extensions are managed.
| Property | Example | Description |
| version | "0.0.1" | The version if this extension. Increase this when publishing updates in order to allow users to update. |
| apiVersion | "1.0.0" | The Saleae API version used. This should remain "1.0.0" until we make changes to the extension API. |
| author | "Mark Garrison" | Your name |
| description | "Utilities to measure I2C..." | A one line description for display in the marketplace |
| name | "I2C Utilities" | The name of the extension package, for display. Note - this does not have to match the names of the individual extensions, which are shown elsewhere. |
| extensions | see below | An object with one key per high level analyzer or measurement. |
The extensions section describes each high level analyzer or measurement that is contained in this extension package.
In the example above, there are 2 extensions listed.
"extensions": {
"metrics": {
"i2cClockSpeed": {
"notation": "N MHz"
"notation": "N %"
There are three different types of extension here, as indicated by the type property. "HighLevelAnalyzer", "DigitalMeasurement", and "AnalogMeasurement". There are some differences between these types.
Type: HighLevelAnalyzer
| type | "HighLevelAnalyzer" | This must be the string "HighLevelAnalyzer" |
| entryPoint | "I2cUtilities.Eeprom" | The python entry point. The first part is the python filename without the extension, and the second part is the name of the class in that file |
Type: AnalogMeasurement and DigitalMeasurement
| type | "DigitalMeasurement" | This must be either "DigitalMeasurement" or "AnalogMeasurement" |
| entryPoint | "I2cUtilities.I2cClock" | The python entry point. The first part is the python filename without the extension, and the second part is the name of the class in that file |
| metrics | "i2cClockSpeed": { "name": "I2C Clock Speed", "notation": "N MHz" } | Object that contains one property for each single numeric metric you wish to display. If your measurement class produces 4 different numbers, all 4 must be present here. Each metric property name must match the name of the metric produced by your python class. |
| metrics[X].name | "I2C Clock Speed" | The display name for a given metric |
| metrics[X].notation | "N MHz" | <p>The display string for formatting the metric. Limited HTML tags are supported: <code>['b', 'i', 'em', 'strong', 'sub']</code> </p><p>Example: <code>"N <sub>t</sub>"</code></p> |
